Making shrouds...
Motivator
Thinking of breaking up some old stock fans I've got and using them for shrouds on my H70, with Kaze 3k's being the fans in use. I'm thinking if i broke/cut/filed off the screw hole tabs on the side of the kaze facing into or out of the case (current set up is fan:case:rad:fan, idea is fan:shroud:case:shroud:fan) i wouldn't have too hard of a time with finding 6/32 screws to fit that length (~63mm and another 5mm or so for rad threads). Anyone with shroud experience have input?
