Making SFF Look Good.
The_Oasis
Hi there again! So currently I'm twiddling my thumbs till Skylake comes out (at which point I'll be jumping on that and the NCase) but while I'm waiting around I've been wanting to ask a bit more on how you keep your cases clean and tidy. I see plenty of the best looking NCases have the custom sleeves for all the internal wires, often color themed, and the general wire-management really makes the case look beautiful when done well.
What I wanted to ask was where I can go to start learning about custom sleeving (and whether it's even worth it or if I should buy some pre-sleeved cables), along with some management tips for working with SFF systems.
Cheers,
Oasis
There's a good few tutorials online in text, video, and image form all you really need to search for is "PSU cable sleeving guide" and you'll find plenty of good guides. :)
For cable management, I go one wire at a time, and determine the best/ most compact route it can take. Then I move on to the next cable until I'm done.
Here's my Ncase with the stock cables that come with the SX500-LG:
