Tuthmose
- Nov 4, 2009
Yet another question from my server re-wiring project. My new HDD hot-swap bays demand a whole bunch of Molex connectors instead of the SATA ones Ive got, but Im trying to keep the budget under control, so Id like to work with the PSU Ive got rather than buy a new one. Rather than cutting the factory-provided leads and soldering on the new leads that I need, I thought I might make a sort-of-modular deal by terminating very short stubs of the stock wires close to the PSU in Molex connectors, to which I could connect whatever lines I needed.
So, the question: is there any reason resistance, inefficiency of Molex connections, etc. that this would compromise the power in the connected leads? Are there connectors I should use instead of Molex for this, in the name of better power-transmission efficiency? Im guessing not, since Molex adapters and such get used all the time, but I'm overly cautious (too many years of experience diving in first without all the info) and figured it couldnt hurt to get some input before I got out the cutters and crimpers . . .
Thoughts pro or con are appreciated . . .
-Tuthmose
-Tuthmose
