jordan172005
- Feb 15, 2006
I am thinking of starting a project and would like some opinions. I have this subwoofer box
http://cgi.ebay.com/Harmon-Kardon-H...ZViewItem?IMAGE467252.x=154&IMAGE467252.y=126
I have already put a 250w powersupply inside of it and hooked it up to the cord comming out of back. I removed the ATX cable from it and connected the greeen wire to a switch and a ground to the switch. The switch works perfectly and turns powersupply on and off as it should. I plan on putting atleast 4 hard drives inside this. I am wondering is there anyway to hook say 4 hard drive up to something that'll have a cat5 female connector so I can plug a cat5 cable into it and plug into my router and share this device?
