jhatfie
- Mar 19, 2003
I am still fairly new to watercooling and I am pleased with my setup, but I am looking to get even better results if possible. This is what I currently have (in running order):
Hydor L30, Whitewater CPU block, DD Maze4 GPU block, D-tek Pro core radiator with 105CFM 120MM fan and shroud, Bay-Rez all using 1/2" clearflex.
I've tried messing around with my configuration, tried a push pull setup on my Radiator, Radiator outside my case, different thermal compounds, but my temps seem to stay about the the same (+/- 1C). About 35C idle and 45-47C load with 22C room temps.
I am thinking that replacing my rez with a T-line might help some by improving flow. Would a different pump help since I have 2 blocks? Maybe something with more head pressure like two of those C-system pumps running in serial/parrallel or perhaps the DD12V-D4 pump?
