Making files non-searchable
Is there a way in windows xp to make files non-searchable? If I make it a hidden file, it can still be found if I check to search for hidden files in the search options. Another way would be to comopress the files and tack on a password-protection on it. However, this would take a very long time since I have large files. What other options out there? I just want to make them non-searchable but still be accessable manually.
Parents searching for your porn?
Not sure what you can do. Put them on a removable drive?
Edit: Rename files/extensions and switch back when you need them.
