I'd like to build a few odds and ends for a project I'm contemplating, but I know nothing about where to start. Too much info on google to sort the wheat from the chaff.
Basically I'm looking for something that can be easily molded, glued (or otherwise fastened) and doesn't look like garbage when it's finished.
Here I use my mad Paint skills to give you a basic idea:
I'm not necessarily planning on making an air duct but it's a good example to illustrate some of the basic problems I'm going to run into; bending the top/bottom pieces, fastening the baseplates to the duct work securely and fitting it all together with a minimum of size increases.
Any ideas on where to start, what tools I'll need etc.? Looking at Crim's Mars City mod (amazing BTW) I see a few hints like Bondo, styrene and instant dry superglue...
