videobruce
- Jan 21, 2005
I have used MS Config for years being one (probably only other than 2000) of the better ideas from M$.
What I don't like is when I resize a collumn, it doesn't 'stick'. Namely the "Command" collumn under "Services" (too narrow), the "Manufacture" collumn under "Services" (way too wide) and the "Service" collumn (too narrow).
What I also would like to do is enlarge the window with the ability of remembering those changes.
I did come across a small program called Resize (or something like that), but that only allows resizing the program window one time. It won't remember the change and you have to have the this program running just to do that. That isn't any help.
Any ideas??
Any ideas??
