Hey, I would like to make a watch folder for itunes.
What I mean by that is similar to the "Watch Folder" ability in Windows Media Player. That is it has a folder (for example, "My Music") which it will constantly scan (or check every once in a while) for new music, that will be added automatically into your Music Library.
On my itunes, I always have to manually goto "add folder" and re-add my music folder so that it can find the new music to put into the library.
Is there a way in Itunes so that it always looks for new music?
Thank you
Thank you
