Hey there,
I was curious as to the best way to make an audio file out of a video file, basically taking away the video.
Do i need a certain program? and if so, which is the best?
thank you
Audacity http://audacity.sourceforge.net/download/
Basically download and install. Run the app, tell it to record "what you hear", then click "record" in audacity, and "play" on the video clip. Edit, scroll, clip, adjust, etc. as necessary.
If you need a better way to batch this out for many video files, then look into "Tunebite". http://www.tunebite.com/
That capability is not the main "bread and butter" of Tunebite, but it can do the job you are needing in a singular or batched format.
