TrichomeKid
- Feb 13, 2008
Just wondering if anyone has experience in making a removable side panel from a 1 piece case cover. I have an old case which uses a solid case cover, meaning all sides come off as 1 piece. This, as you can imagine, is pretty annoying/bothersome to remove and put back on.
I figured I could just cut the one side so only that side has to come off to mess with the guts. This would in theory work, but there would be a gap at the cut spot that would look pretty ghetto.
Any ideas?
Any ideas?
