So I recently had a T1 installed at my place of work, of which we are using a laughable 5% on average.
I have taken it upon myself to build a server and do my T1 some justice. However, I don't want to spend an arm and a leg. Here are my questions:
What exactly is meant by 'hot-swap'? Does that mean I just have to take the cage home, stick it in my fileserver at home and viola? Or do I have to actually plug in the cables?
For just sharing files, Im assuming I don't need a big hoss of a processor, something ~2GHz should suffice, yes?
How much memory will I need?
The file sharing medium of choice will be BitTorrent, so I doubt I will need a bunch of ram for FTP clients.
And finally, if anyone can suggest a good pre-built affordable system I would be all ears. Im looking for something with at least one hot swap, CD-RW/DVD, 1 Unit Rackmount. Those features are absolutely set in stone, everything else is up in the air.
Thanks for your help
(c:
(c:
