I am thinking about doing a temperature sensor mod so I can measure the temperature of the water in my upcoming watercooling project.
Here is what I have:
1. A Typhoon Dual 5.25" bay reservoir:
http://www.sharkacorp.com/images/typhoon/dbb-lg.gif
2. A Matrix Orbital LCD kit:
http://www.crazypc.com/images/cases/caseaccessories/lcd/mx610unitfull.jpg
3. A temp sensor for the LCD kit:
http://www.crazypc.com/images/cases/caseaccessories/lcd/thermalprobefull.jpg
The Matrix Orbital can display a wide range of information and is fully customizeable. I want the LCD to display the water temp.
I've been reading these threads to get some ideas:
http://www.hardforum.com/showthread.php?t=929488&page=2&pp=20&highlight=inline+temperature+sensor
http://www.ocforums.com/showthread.php?t=304440 (scroll down a bit)
Notice the two holes at the bottom of my reservoir:
http://www.sharkacorp.com/images/typhoon/db-fit1-lg.gif
The outlet of my res will come out of that hole on the right. Basically what I am planning to do is take that nipple on the left, fill it with some kind of epoxy and stick the temp sensor through there. So when the epoxy sets it will be hard, and when I screw the nipple into the reservoir the temp sensor will stick out into the water.
That way the temp sensor will measure the temp of the water nicely while not interfering with the flow in any way.
In theory it should work out nicely, but I really want to make sure this is done 100% tight, as I am very afraid of leakage. So I need some advice on the process.
First of all, what type of epoxy should I use? Will this type of stuff work?: SureHold 90 Second Epoxy. I also have a tube of Wood & Furniture Goop handy right now. It dries to a waterproof, rubber-like consistency. I think it bonds well to plastics. Could this be a good thing to use, or is it to "rubbery"?
The guy in the linked guide above uses JB Weld. Where can I get this? Is it any better than the epoxy I can get at walgreens?
Also, should I stick the temp sensor through the epoxy-filled nipple before the epoxy sets, or should I drill a hole and then stick it thorough after it sets? If the latter is the best option, how do I reseal it after sticking the temp sensor in?
Im planning on coating the temp sensor lightly with clear nail polish to make sure its waterproof.
I am just looking for some advice and tips before I begin this project.
Any help is appreciated. Thanks a lot.
