MikeTheOven
- Jan 31, 2015
So i have 2x 7970 Sapphire Dual X OC editions with EK supremacy waterblocks (the universal kinds). I really want full WBs for my cards. For overclocking and VRM cooling. Anyway, here are my cards and why the block wont fit:
http://www.overclock.net/t/1321606/sapphire-7970-oc-v2-is-not-reference
Basically just 2 capacitors bocking the area which would've been covered by a full cover WB. Well, that and there is another choke on the other side, which i doubt has any difference.
Anyway, is it possible i unsolder the 2 capacitors and RESOLDER them on the other side? on the back of the gpu? I had a look, there is A LOT of space around them so they wouldnt interfere with anything else.
Reference PCB: https://www.google.si/search?q=heat...nce.com%2Fhelp-video-card-pcb-layouts;800;401
Is this a possibility and is it advisable?
Thanks guys!
Thanks guys!
