dark_light
- Jul 13, 2006
Hi guyz
I needed a number of 20ft long usb extension cable.it wasn't availabe in my town so i decided to make one and give it a try.i got a normal 2ft one and cutted it half. i got a 20ft cable that contains 4cables in it and just connected the 4 wires at the 2 ends of USB cables. I simply scratched the thin wires and folded them with the corresponding cable and then covered by scotch tape so that none of them gets short with eachother.
Now the problem is that when i connects something to the other end then computer doesn't recognizes the USB device. Though it detects that a USB device got connected.
What could be the reason. Do i need to solder the cable joints .Will it fix the problem?
