Maker EVO Deluxe
CapTen
Welcome to my next Project:
„Maker EVO Deluxe"
After a long time of thinking, I've decided to do a more complex Casemod. Lets see what I'm doing with it.
To be called into action is coming the brand new Mastercase Maker 5.
Inspired was this Mod from the Mitsubishi Lancer Evolution.
The interior was completely cleaned and covered with pale Leather. For the Cables/PSU Area a Cover was created in the Design of the Case.
It should be installed a lavish Watercooling with Brasstubes and Chrome Fittings which should seems like a Header.
The AGB will fitted justified in the front of the Case, so that it will be one unit on that case and be used as brake fluid reservoir.
At the Case you will find some air scoops, which are normally founded on engine covers or fenders., which will be made from me out of Aluminum Plates.
At the Leather I made different punch works.
Here and there will be a Wing installed together with Headlights and one DTM Axle Back Exhaust.
The Theme is called Sportcar and I will try to make as much Details as possible.
Hardware:
Case: MasterCase Maker 5
Graphiccards: 2 x Gigabyte GeForce® GTX 1080 Xtreme Gaming Water cooling
Mainboard: ASRock Fatal1ty X99X Killer/3.1
CPU: Intel Core I7 5820K
Ram: 8 x 8GB G.SKILL RIPJAWS V DDR4 2666MHz
SSD: HyperX 3K Limited Edition White 240Gb
Netzteil : Gigabyte XP1200M
Watercooling:
Pump:Alphacool VPP655 - G1/4 IG inkl. Eisdecke D5 - Plexi V.3
CPU : Alphacool NexXxoS XP³ Light - Brass Black Chrome
Ram : Alphacool D-RAM Modul (für Alphacool D-RAM Cooler) -...
Alphacool D-RAM Cooler X4 Universal - Acetal Black Nickel
GPU : 2 x Gigabyte GeForce® GTX 1080 Xtreme Gaming Water cooling
AGB : Alphacool Eisbecher 250mm Acetal Ausgleichsbehälter
Radiator: Alphacool NexXxoS XT45 Full Copper 240mm
Alphacool NexXxoS ST30 Full Copper 240mm Radiator
Brasstubes : Alphacool HardTube 13/10mm 90° Messing Chrome 10/50cm
Hardtubes : Alphacool Eisrohr 13/10mm Plexi (PMMA) HardTube Satin...
Alphacool HardTube 13/10mm Plexi (PMMA) Klar 80cm - 4er Set
Fittings : Alphacool Eiszapfen 13mm HardTube Anschraubtülle G1/4 für chrome and black
Fans: Enermax T.B.Silence 14cm
Enermax T.B.Vegas 12cm weiß
Accessories:
Aluminum
Acrylics
Wood and MDF
white Leather
Blank Leather
Punch iron
Swivel knife
Color, Coating Spray
Pipe Bender​
A huge thank to all who supported this Project, without your Help
the Execution of this Project wouldn't be possible.
little preview :rock:
:LOL:
Hello all !
Here I want to introduce all components used again.
I had the last week but frequently walking day :D
Here the ASRock Fatal1ty X99X Killer/3.1. I think the contrast of red green really well.
A motherboard in free wilderness not seen so often, still untamed :vain:
2858718
2858719
2858720
2858721
2858722
the Gigabyte GeForce® GTX 1080 Xtreme Gaming Waterforce
2858723
2858724
2858725
the Gigabyte 1200W Power Supply XP 1200M
2858726
here the Enermax T.B.Silence in 14cm
2858727
and that´s the T.B.Vergas White in 12cm with white LED´s
2858728
2858729
and here many components from the new Alphacool Eis-Serie
2858730
2858731
2858732
2858733
2858734
2858735
2858736
2858737
2858738
2858739
and here again the Mastercase Maker 5 with tempered glass window and mama and papa swan :p
2858740
2858741
Despite still missing parts I could not let it remain and have begun already times.
So let's get started!
First, as always, the case was made naked.
2858742
2858743
Now it went straight to the air intake slots of a fender. Dry runs I had behind me so right now.
I transferred to aluminum the dimensions of the front and mark the position of the louvers
2858744
Now I have a positive and negative form for it to create the aluminum during peening / flanging (as called the molding of aluminum at all ?, I do not know it) does not tear unintentionally.
But I've just the 4 different slots milled in MDF and fits to the counterpart
2858745
2858746
2858747
Now cut the slots in the wood
2858748
then all processed with the hammer and the shapes and cut out in the end only from the large aluminum plate
2858749
it goes on with a front spoiler, only cut the spoiler lip from acrylics
2858750
Try and think of something I had an image in the head thereto and have more acrylics radicals tailored and trimmed ground
2858751
at the same time the rear spoiler is made. Here I decided for MDF.
First of coarse cut design
2858752
and now missed the whole a Aerodynamic shape. This reminded me when working on more planes than cars :D
2858753
The bottom 3cm where the spoiler on the case is I have glued a second MDF board, have not photographed but in the later images of the painting you can see the spoiler down around gets thicker
2858754
2858755
sry Images limit
after I was now on all operations of the front spoiler in the clear I have glued the various acrylic parts with each other
2858756
then I bent from aluminum small wing spoiler
2858757
then everything was primed to start the filling, just the front spoiler had to be done much
2858758
2858759
2858760
After the water cooling has arrived, it went to the cutout for the reservoir
2858761
despite a PVC cutting disc that work is always pure torture
2858762
but just as I had imagined
2858763
only new holders for the reservoir is made.
Preferably 3mm aluminum angle, still remainder of my desk;)
2858764
2858765
casually, because of all the dry processes the spoilers were always times filled and primed
2858766
The opening behind the louvers had to be cut
2858767
Now the radiator grille
2858768
the rear spoiler was now ready for painting, so I have all the holes for the mounting set and the actual wing cut to size and glued. Here again 3mm acrylic glass
2858769
2858770
after gluing with epoxy adhesive the connections equal primed and filled
2858771
2858772
after the radiator grille was now cut out
2858773
I find the optimum position for the small wing spoilers and those glued to the alu sheets with the air slots
2858774
is slowly taking shape
2858775
A DTM exhaust is also planned so a aluminum bracket was cut
2858776
and then drilled holes for the exhaust pipes
The exhaust is then the way from a few remnants of brass pipes and fittings with 45 ° angle.
A 1 / 4Zoll thread cutter I have not yet, I ordered yesterday and should still arrive this week
2858777
here I had everything tested, by lacquered whether I like the result. One often sees irregularities only when it's done, so better now before there is no time. :LOL:
2858778
2858779
the holders of the reservoir were also painted, are here mounted
2858780
and fits beautifully
2858781
What next? Headlights: P
cut 1 cm acrylic glass strip and only once sanded quite a while and burnt fingers
2858782
Now I have this cut and polished in the headlight shape :doofy:
2858783
had himself photographed really bad
2858784
2858785
I've cut and folded the front grille of the fan guards from Case, this will sit flush with the front spoiler lip as of 8o
2858786
next update tomorrow​
Nice fab skills. I like seeing actual case modding. I see the pics of components in the woods and set on concrete or grass and I am curious how many funny looks you get carrying PC components out in the woods for pics. Hahaha.
Thank you and
Hello!
As announced I made a small engine bonnet.
For that I have transferred the fan opening from the lid on aluminum
2859273
then I have again created me two forms to reshape the aluminum
2859274
now deformed and cut out the aluminum
2859275
looking for something I can build a engine bonnet breech, I found it here (right the original)
The pins I cut to length and each provided with a hole
2859276
then halved a key chain and so it should look like
2859277
after it was painted, I have the engine bonnet covered with carbon foil and glued the bonnet breech it
2859278
2859279
The chipset cooler from the motherboard had to change their color
2859280
2859281
2859282
Then I started already times to relate the radiators with leather
2859283
2859284
2859285
attempts me times on a small piece of wood, with 2 cm foam material upholster on
2859286
2859287
2859288
the headlights I also equipped already with Led's
2859289
2859290
for the area in front of the IO panel I had to create a cover because you could see from there quite well behind the radiator or on the reservoir
2859291
2859292
to let red disappear all the motherboard I have folded a small aluminum sheet and painted to cover all Sataports
2859293
2859294
2859295
Cpu Holder was also repainted
2859296
The cable duct in the MB tray had to be moved, I got him simply cut out and placed to the left behind the Radi bracket
2859297
2859298
The Ram modules I have also mounted casual.
but ran is not according to plan. The GSkill have only one side of memory so she slipped always out of the bottom.
I have also used it nor the thermal pad of the original cooler.
Now when I wanted to mount the cooler on the modules, a problem again. The screws are all 2mm too long. So I got all screws 2mm shorter sanded, unfortunately, had no right here
2859299
2859300
2859301
so much for that than next I have the exhaust manifold from the brass tubes tinker.
2859302
The next update!
Sorry for some images, with Energy Drink in the blood, it is difficult to keep the camera calmly XD.
As recently already announced I had my first time a form for the 13er brass tubes build.
So get bought in the hardware store and a 15er copper pipe and bent this.
On the second try that also looked very presentable.
This bent pipe and a piece I've just halved with the Flex and sanded smooth.
Now I have a perfect shape for the 13er tubes
For the motherboard tray I have a 3mm aluminum plate cut and screwed into the Case
then sawed wood on the later, the leather is fixed
Now the holes for the pipes and cable set.
the pipe penetration needed 17er holes, so I first with a cone drill holes drilled 16er and finally even with a size 17 drill afterwards
after the 1/4 inch thread cutter was there I was able to secure the DTM exhaust.
Just stupid that the angle was too thin so I decided from 3mm aluminum sheet suitable nuts cut and there purely cut the thread.
Not pretty but rarely does what it should and can not be seen anyway.
matching brass tubes in DTM style were then cut to size
This is what I can actually save me but I speak the topic anyway.
After a little practice with the brass tubes and tube bender I have created the loop in the interior.
and Cutt! I knew it! Every time I say to myself, do not start before the hardware is there and I have made the mistake again.
My plan was to pack the graphics card in the lower 2 PCIe slots to have up enough space to tinker from the brass tubes a exhaust manifold.
Yes if you plan in advance is all in vain.
Coolers of graphics cards are too thick, you can not use the lower PCIe slot, even if the Mid tray comes out only stay 5mm up to PSU.
Then there would be no more room for the wooden board with the leather and the PCI outputs on Case would also be extended by one.
The loop at any rate nothing that cpus come up into it, half of the tubes I could accommodate but first I needed new.
Well that later.
Now I have set the position for the AIO radiators of GPUs. One comes before the power supply and the second comes from the back of the case.
only times sawed So for the first hole in the ground
then put the hose guide from the AIO in Midtray
Then, an angle was cut carrying the pump and the second radiator of the AIO
around the pump to be positioned as flexible as possible I have set oblong holes. For milling these holes I need to buy a cross table to me.
Here I drilled only at the beginning and end of two holes and cut out the connection.
then cut two angles and a flat bars for the radiator
then I fastened spacers for the rear side panel. (P5 Style)
well as already mentioned I have to make different loop so I displaced all the holes in the pipe carry out, just like the first time with cone drill drilled to 16mm and a 17mm drill afterwards.
the old holes I closed with aluminum kit and 2K Filler again, back simply tape it so that it does not fall through, which you can then easily be removed or sanded again.
after sanding nor a twice fine fill in and ready
Now I have bent the window for the back to match the shape of the Cases
around the compressions of the outer corners in bend can not be seen. If the Window cut to size after the bend. Delicate matter I know.
Beautifully clamped the whole and every 5cm goes be reclamped thus merely nothing wrong.
The side which closes the front is then beveled so that it nicely with the Case
fits perfect
sawn off only the top and bottom
cut out another hole for the fan
and this then freed of unnecessary ballast :rolleyes:
fits also perfecly
Now I have the brass tubes to re-cut and bent.
First of securing the pipe bender neat, which is even something of unwieldy and chromed tubes slip easily
then all aluminum parts were primed with filler and with aluminum primer
all cutting edges on Case I have with color (Paintbrush) overlined to the rust prevention even if this is not the best method.
Now I have the wood panels covered with leather
The holes should in fact be stung with a Hollow Punch, the ground was too soft so I had to cut it with a knife. Not very clean but is concealed by the fittings.
Now I have all the parts ready lacquered.
so now the next challenge: a PSU cover. So that you still can still use the Window and open.
So, at first bent a plexiglass
Below only slightly slanted so as I said, the window can still be put in Case
then completely cut to size and put yet holes for the tubes
Then I measured everything, position of the power supply etc. and the design transferred. here until the surface is the leather-covered
this surface then brushed with 40 grit sandpaper so that the contact adhesive holds
Now I glued the leather on it.
then I have three or four hours spent with the transfer of the film. You believe it or not, but for the whole PSU Cover I was good for 8 hours. That was not planned: P
Before leather I had already made a Fillup, everything was tight. Get tomorrow everything reinstall and start with the cabling.
Little things are still, Window outer edges polished, correct a few pipes at the loop, what you always see only the photos and operate at all corners yet tweaking.
a Sli bridge I wanted to build but a little time still remains for me. :D
HIHO!
Up to the last update!
all Alphacool logos were exchanged Chrome logos and the CPU holder got something orange accents.
for I was determined a half a day busy with weeding the stickers, but they were not the only stickers
as you can see the adapter fittings from behind, this had to be painted black
then I've yet created a SLI Bridge and this cut from 2mm acrylic glass somewhat obliquely cut and glued together
this has been repeatedly painted before and painted in the end black and covered with foil (the design of the graphics card) Unfortunately, I have a separate image of this, you can see it but the final images.
On that PSU Cover I back side glued two strips to slide the cover exactly on the Mid-tray can.
before Foiling the front I had to eliminate some damage
then the cut edges of the windows were yet polished, unfortunately this is the best picture what I could get
Procedure: first scrape the edges with a scraper smooth, then sanding of 300 to 800 wet sandpaper, then polish with two polishing pastes and a felt pad and the very end with car polish and a cotton disk to mirror polish
Now I have the front covered with Carbonfoil
Now I have the fenders on it glued, with double-thick adhesive tape, looks like a thermal pad, it has the appearance of a sealing rubber. ;-)
The headlights and the radiator grille will now also be glued, the Fronspoiler was screwed
the Xtreme Gaming stickers Gigabyte I can yet plotting to three times the size and for a small aluminum plate designed as a backing to give it some depth profile.
This I then primed, painted, transferred the sticker and all onto the PSU cover glued
For lighting I have two LED strips soldered with dimmable remote control handle.
As under car illumination a black light LED comes strip used, these had a loose connection so I renewed the cable.
for the black light I still have cut an aluminum strip on the I Stripe glue. The strip was then glued centrally under the Case
one day I was busy with the cabling
also had at every corner yet minimal corrections are made
PSU cover did not fit completely, because of the Radi AIO was in the way, so I've cut out the cover below a small recess
Brass pipes were all again adapted and something shortened because but a few things were not quite satisfactory.
-an appropriate coolant I have mixed in distilled water and Mayhams Dey Yellow and Red.
Now the worst after I had filled the Sys yesterday again with the correct Coolant and all just sample ran, there was an after 5min ZISCH and reservoir was empty.
One of the brass tubes slipped from the CPU cooler and the pump has pumped their entire contents to the CPU / motherboard.
super, something one day before completion.
Well the Sys was out, it was only the pump, but I am a bit nervous to start the system.
Yesterday I naturally everything dried again, mixed new Coolant, refilled again, and the whole then as to run through the night.
So the Final Pics!
Currently there is absolute chaos here have no proper place more. The quality of the images is modest beautiful, I will do the same next week new, as little taste, I hope this rich images
Not a big fan of the "spoiler" but love the car like tube design. I did not know you could bend thees alpha cool pipes without them braking
kk sorry for being to late.
Maker evo deluxe won the third place on DCMM 2016.
I think its good for only two weeks time to work:)
and thats me :D
