Ackkk,
So in the pursuit of not having to buy a product sold as UV dye for 5 bucks, that was probally made using shoe polish and two ripe turnips, I decided to set out on a quest to make my own. So I tried adding numerous things to my resiliant pump. If your queezy about damaging pumps please read no further. That said my pump runs fine! I tried adding a few dabs of glow in dark paint to Demin water but didn't get much. So I added a few more dabs, with a little bit of blue and it looked better but not much. I even filled the reservoir with it after filtering it through a coffee filter. That was ok but I needed more. So I tried using food coloring but alas it had no UV properties. Then I happened upon a post about using gel pens to draw inside your case. I bought the gel pins, and didn't see much drawing they would do on anything other then paper. So what to do with me gel pens??? I broke em open and cut em up. Took some water and stirred it up with the boken half of the pen. More stir more color. Then tested it in the UV and lo and behold it is as bright as the orangest orange!!. So I puts it in and am good to go.
As for pump damage I strongly doubt there is much in terms of chemicles that would cause any damage to any parts. This of course assumes that the life of many pumps will likely be short (1-2) years in the pursuit of newer and beterest technology! So if you are not a pump pansi please try and see what you think. Or, just buy the dye as the pens do cost almost half as much..heh
