list of stuff you need
rubber/foam pad 1.00 -------the ones i found are either 2mm or 3 mm thick
flex glue 3.99-enough to make 5-8 12in x 18in mouse pads
cloth 2.99 - enough to make 2 12inx 18in mouse pads
now the cloth is a big deal..if you pick out thin cloth the glue will blead through and it will look like crap. If it is too thick it will feal wierd and will annoy you after 10 minuts of gaming. Two that i found work well are black denim and microfiber...the microfiber might bother some people but it doesent bother me.
this is the cost
I have found that this glue works fairly good http://i1064.photobucket.com/albums/u364/onefatguy/DSC09992.jpg
ok step one apply glue
step two spread with brush if you end up with big globbs smooth them out IT WILL BLEAD THROUGH
step three apply cloth and smooth out with your hand ----remember if it dries lumpy it will feal lumpy when you go to use it------
step 4 let dry over night
step 5 trim to shape and size
i will also do some looking around to find larger pieces of foam/rubber pading---i eventually want to make my dest top into one huge mousepad![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
this is the cost
![DSC09998.jpg](http://i1064.photobucket.com/albums/u364/onefatguy/DSC09998.jpg)
![DSC09993.jpg](http://i1064.photobucket.com/albums/u364/onefatguy/DSC09993.jpg)
![DSC09994.jpg](http://i1064.photobucket.com/albums/u364/onefatguy/DSC09994.jpg)
![DSC09996.jpg](http://i1064.photobucket.com/albums/u364/onefatguy/DSC09996.jpg)
![DSC09995.jpg](http://i1064.photobucket.com/albums/u364/onefatguy/DSC09995.jpg)
