My pump made a higher pitch and louder noise than I cared for. Quick fix.
$2 for Nu-Foam at Wal-Mart
Measure and cut some pieces
This is a Lian-Li v1000, so I don't have to see my white foamish stuff
Insert
Done... and it works very very well
Oh, and this Fun Foam from Hobby Lobby sells for $1 per sheet. Works wonders as a vibration damper and it's a LOT cheaper than actual damper material
Insert
