Folks,
I've got "security system in a box" setup. It came with 8x 1080p PPOE cameras, an 8 port switch, and a DVR. The cameras are all TCP/IP.
It works. All cameras are up and running and I can access the DVR from any computer on my home network.
However, the DVR is SLOOOOOOW. I can barely get it to replay any video without timeouts and dropouts. The software is hard to figure out, as well. (I access it via TCP/IP on my home network.)
I've got some spare computer hardware. I'd like to build my own Network Video Recorder, but don't know where to start. Sure, I can toss a motherboard/cpu/gpu into a box, and plug the satellite switch into it. But, what software do I use to run the system? What do I do after I click the Ethernet cable from the camera satellite switch into the mobo network port and turn on the box?
I'd like to be able to record a full 1920x1080x30fps from each of 8 cameras and have full replay ability from any recorded stream, as well.
(I assume any security software will allow me to setup the cameras for record on motion, record on time, and record manually, as well as any other "normal" functions.)
Where do I start???
Thanks,
Ken
Where do I start???
Thanks,
Ken
