Make me a case recommendation with these requirements:
Tutelary
I'm a nice banned boy.
2 120mm fans. One front, one rear, nothing else. I dont mind a bit of plastic ala chieftec front door style, but it would be nice to be all aluminum. I HATE flip top ports for "easy access" etc on the top or front of the case for things like usb ports, mic ports etc. It would be *really* nice if the case had easy to remove dust filters for the fans, I'm incredibly tired of cleaning my system out (clean freak).
Lastly, and most importantly, what case do you have which closely fits these requirements that you really just enjoy owning, it gives you that little something special thats hard to define?
thanks!
Um....have you tried just browsing www.newegg.com or any other e-tailer.... It seems kinda lazy of you to say "Pick me out a case and I'll tell you if I like it or not" Do youself a favor and look yourself.
well, thanks for the help champ. In case you missed that last paragraph, I'm also looking for that personal appeal. I'd like to hear other users out on what they like about their current cases which might fit several of the criteria mentioned.
your current score is zero. please, dont bother to play again :D
Looks like you're getting off to a great start....
Antec Super Lanboy fits the reqs, pretty cheap, anything with a metal front-panel is going to cost you alot more.
I would recommend the Lian-Li 7BW. It has 2 120MM fans and I think it has a 80MM blowhole which can be modded to a 120MM (3 x 120MM right there). I have the Lian-Li PC-60 and its a great case, its the same thing as this one, except it has 80MM fans instead of 120MM. Lian-Li makes great cases, excellent build quality and are very sleek. A lot of people on this forum can vouch for this case's excellence...
Edit: You can check out the Lian-Li PC-60APlus as well...
Well I dont feel like being a jack-ass right now :) Sorry bout that. I think you might like the Lian-Li v1000 case...really expensive but good!
They come in silver and black:
http://www.newegg.com/Product/Product.asp?Item=N82E16811112055
I personally want one, but I don't have the funds currently. I think you'd be happy with this oue, and I'd be willing to bet that you could put a dust filter on those fans if you really needed it!
