My setup is as follows....
Abit NF7-S
Barton 2500+ @ 11x200
1 gig of kingston HyperX
550w Enermax
ATI Sapphire X800 XT PE
120GB WD SE IDE(Win2k, old stuff, stopped using the OS a few months ago when I got the newer drive and installed XP on it)
250GB WD SE SATA(WinXP, current stuff)
250GB Maxtor IDE (Misc. Storage/backups from other drives)
(All drives using NTFS)
So in windows xp I had been having some problems with poor prefomance in games and such recently. Tonight I decided to try reinstalling some drivers. I removed all my video card drivers then used driver cleaner and regclean in safe mode. As soon as I rebooted I got a BSOD "STOP: 0X0000007B..." I can't boot into safe mode or last known good configuration.
So I figure I will need to reinstall xp on my SATA drive so I boot into win2k without any problems and I copy a few files from my SATA drive onto my Maxtor storage drive and download some drivers from the internet that I would need to install. Copied them over to their own directory on the maxtor.
I then found my winxp CD and booted into the install when I realized I would need to find a floppy to hook up to try and install/repair on the SATA drive. I come back to my comp and it has rebooted itself, probably because I didn't do anything in the install prompts to continue.
So it goes through the setup again and when it shows me my install options I see my 120gb drive and then for my 250 GB maxtor storage it says that its all unpartitioned space. Now I think "that can't be right". I turn my comp off, reset the cmos and boot into win2k again and my maxtor drive which I had just been using fine before is now not showing up under my drives on my computer. Tried rebooting still no go. It's still listed under the device manager but I suppose there IS some kind of partition table damage.
Now I don't see how this can all be related but perhaps?
WinXP install takes a shit after removing catalyst drivers then using driver cleaner pro + regclean.
Used my win2k install on my old drive to copy some files from my SATA drive to my storage drive + downloaded some drivers onto it.
Storage drive is unreadable by windows.
Devnull going mad over it all...
I can't just format all the drives in question as I have plenty of files that I first need to recover atleast. Any ideas on what happened? recommendations? For now I am disconnecting my storage drive and I found my SATA drivers for my mobo so I am going to attempt a recovery or a repair install on my SATA WD SE drive but as for the other drive and my problems in general not sure.
Abit NF7-S
550w Enermax
