Major problems with my Dell 9300
MANDINGO
Hello fellas, Ive had this laptop for over a year and a few days ago when i turned it on there was like blue lines going down wards on the black Window loading screen, then some white lines across the screen flashed up and after that black screen.Never able to see desktop just black screen after the last white lines.
Thats all i get,after turnning it off and on i was able to load it in safe mode and it works perfect on safe mode?
Any body have any idea whats going on? The warranty is over so not sure what to do ?
Any advice is greatly apreciated.
graphis card 6800 go 256mb
1gb ram
2.0 Pentnium M
It sounds like the video card. If it works fine in safe mode, there's a possibility it's a driver problem. Try cleaning out the video drivers and re-installing them.
I agree...uninstalling the video drivers might fix your problem...the good news is if the video card is bad, they can be had for pretty cheap (vs needing to pay $400 to replace the entire motherboard)
