MAJOR problems with ECS - H67H2-M2 mobo...
Ashton
I'm trying to upgrade a desktop, and the system is constantly BSOD'ing and also refuses to let me monitor use it's native 1080p resolution...
System is running an Intel Core i7 and 4x8gb ram.
I first tried to run it on my old vista install but it kept crashing. with "IRGL not less than or equal" I pulled my graphics card and it ran.
I installed vista and upgraded to Win7 (since vista doesnt support 32gb ram) and outside of the onboard video forcing my monitor int 1920x1240 or something (on both VGA and HDMI connections) it was running fine. Installed all my programs, no problem except the resolution... then windows update hit and downloaded a bunch of updates.
Now it BSODs with "memory management" or "system service exception" or it just freezes up when I turn it on and it says "preparing to configure windows"
The manual claims the board only supports 4x4gb of ram, the internet claims it supports 4x8gb, so I dont know who's wrong...
Anyone have any ideas what's wrong and/or how to fix it? As of right now I have a $600 paperweight on my hands... (the only option I see is to reformat again and not install any updates... and deal with a "squashed" screen since the resolution is wrong...)
Have you tried memtest, or even sticking in known good memory?
Also are the sticks you bought on their compatibility list?
I ran the memory test and the sticks checked out good.
Trying to find a list of known-good brands, just checked the manual and if I'm reading it right, the PC only supports upto 1333 and this is 1600... the official website is not loading for me right now... (pre-post-edit: I got the website up and the brand is not listed... but there are 1600mhz modules listed so speed *should* work...)
(keep in mind I bought this as a package deal "barebones kit", so presumably the seller should not have sold me incompatable parts... -_-*)
Last Known Good did not work, but I booted safemode and it rolled back the changes from windows update, I restarted in normal mode and for the last 5 minutes or so I have had a black screen, mouse still moves but PC so far hasn't booted up, not sure if it's going to or not (currently running on 2x8gb) At the moment I have no other compatable ram to test... will try digging around and seeing what I can find...
EDIT:
Hard rebooted.
Got as far as the login screen, once I logged in and it said "Welcome" the screen went black, then a few seconds later I got a BSOD for "NTFS.sys"
Have you tried running on a single stick of ram yet?
To me this sounds crazy, but I tried it and it seems to work! (except the display still refuses to do 1080p)
However this means I'm now running with 8gb of ram total... any tricks to get the other slots to work? (I might see if I can swap it into a 4x4gb system later, at least I'll get back upto 16gb)
Use a single stick of ram and try updating bios to latest version
Found an update to the BIOS, will install it and report back if it fixes.
EDIT:
pfft... bios updater doesnt work... "Error Code4" and because they brilliantly named it eBLU I cant google it without getting a million results with "blue" in them...
Just to let everyone know, it WAS a ram issue, I found another PC that used the same ram (DDR3) and swaped out 4x4gb sticks and it's booting fine, and when I updated the Nvidea (NOT the mobo graphics) I'm getting 1080p again.
Looks like it just simply does not support 32gb like it claimed...
Yeah, it looks like if you run SB, then it only supports 1333, IB supports 1600.
So you might have to manually change it.
How many different memory tests did you run, and for how many days each?
About the only known-good memory is Samsung and no-heatsink Crucial because almost everything else is made with chips that are either overclocked or are factory rejects, and that includes every major brand, lifetime-warranted part.
The ECS website says the H67H2-M2 (V1.0) does support 32GB of RAM:
http://www.ecs.com.tw/ECSWebSite/Pr...oryID=1&DetailName=Feature&MenuID=103&LanID=9
