Major Problem: Windows Explorer Has Stopped Working
dangfx
So all of a sudden, out of nowhere, I have been getting this message. I click restart the program, and it just pops back up again! It happens over and over. And I can't do anything while it's up on the screen! It does it in safe mode as well.
I'm running Windows Vista Ultimate, fully updated. This just started about 2 hours ago, without ANY changes to the system (updates, downloads, new installs, etc.).
When I click on Details in the diologue box, this is what I get:
Code:
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	explorer.exe
  Application Version:	6.0.6001.18164
  Application Timestamp:	4907e791
  Fault Module Name:	MpegSplitter.ax
  Fault Module Version:	1.0.0.4
  Fault Module Timestamp:	44687a2a
  Exception Code:	c0000094
  Exception Offset:	0000000000009a58
  OS Version:	6.0.6001.2.1.0.256.1
  Locale ID:	1033
  Additional Information 1:	5b0a
  Additional Information 2:	baf7e3297b2fc005626465eda53e1b49
  Additional Information 3:	1890
  Additional Information 4:	d13881fce7e43e949d6bec92728e9253
mpegsplitter.ax - probably means it can't thumbnail a video correctly. Delete the video (ctrl-alt-del start task manager, run cmd.exe, del filename.xxx) or update whatever you use for codecs.
figured it out... it was part of the K-Lite codec pack. Probably got corrupted or something. Dunno how though. Uninstalled it and now everything is fine :)
Hate to bump an old thread, but...
I was having issues w/ Media Player Classic Homecinema x64, and thought it might be a codec related. I searched out and downloaded K-Lite Codec Pack 64bit (380). Rebooted, and instant problems. "Windows Explorer has stopped working" Restarted over and over. I had also updated the drivers on my Asus 4890, so I started with ATI. Rolled back the video card driver from safe mode. Still had the "Windows Explorer has stopped working" message. Uninstalled K-Lite from safe mode. Problem solved.
This thread was a lot of help; applies to W7 x64 too. Not just Vista.
recental y i got this error on my Vista
i dont dont have K-Lite installed on my pc
