For all I know, since I am *operating* a system, this belongs here. Ha. It may be a hardware problem but who knows. This computer's specs:
Athlon XP 2500+ Barton
Raidmax PSU - 16A/25A/14A - 350 Watts
WinFast K7NCR18D Motherboard
Corsair XMS PC-3200 512 MB RAM
ATI 9200 All In Wonder
Maxtor 60 GB Hard Drive
Lite-On 12x DVD-RW
Generic 48 x 24 x 48 CD-RW
Stock Heatsink + Delta Fan
Idle/Load Temps: 41C / 45C
This has happened quite a while ago. I ignored some of its "warnings" and suffered it more later. This computer decides to randomly reboot, with less likely to reboot as you leave it idle (vice versa-- more likely to reboot as you use it more). Suddenly, it refuses to boot up as its full speed (166 MHz DDR 333). I had to downclock it to 133 or 100 to even make it work. Then it gets worse, when I restart the PC or boot it up, the computer runs but not on display (monitor). Absoutely nothing shows on the display (monitor) It takes an on/off switch on the back of the PSU to make it work. But then again, it stops working again. Works onlyly when I force the FSB to be extremely low. Now sometimes it does work but now, it seems like everything doesn't work. Windows XP is unbootable, comptuer reboots by itself after the splash screen/loading bar runs. It does so every time. It shows a missing/corrupt file so I did Windows XP set up and did 'fixboot'. That did nothing. And by the next Windows XP set up, it came up with a BOSD with STOP: 0x0000008E (etcetcetc). It is the most painful thing I've ever had to come across. Everything is correctly set up. Is it because of the power supply? In fact, I've reformatted this PC three times with the same type of problems. Just that every format, it progressesly becomes worse and still comes back at you with the same problems. I don't get it. Now, I can't even format it, it comes up with a STOP error and such. It's right now rebooting over and over right here. Sometimes it won't even boot up unless I have it at default settings (bios). Yowch! Help someone?
-J.
Lite-On 12x DVD-RW
-J.
