bassballboy
- Apr 25, 2007
So I've come to figure out through process of elimination that the XFX 4770 in my friend's setup that I just put together is causing my problems with the build...
Whenever I try to install new drivers for the card it makes it so the system crashes after the windows startup screen. The only drivers that work are the ones that comes with th CD, if I use the ones off of the their newest drivers via their online system it will cause the system to fail...
Any ideas? This is a fresh, brand new build.
Edit:Correction, now even those drivers don't work. Could the card be bad? How would I be able to tell?
