maintanence questions (watercooling)
stockwiz
I've had a water cooling setup going for a year now and I haven't done anything to it really. All the parts are quality swiftech stuff, and the loop has 1/4 dexcool to 3/4 water, with about 10-15 drops of pure iodine I got from a local veterinarian. There's no sign of any solids or growth of any kind in the water, it looks as good as the day it was filled, except I noticed a bit of cracking on the o-rings around the radiator, and I have been able to detect the faint smell of anti-freeze for some months too, despite the fact that the water level hasn't gone down at all.
So how often do you strip down your loop, if ever? Do you take it all apart and check all the o-rings to see if they are working fine? Do you ever replace o-rings? Is there a set interval when the liquid should be changed in the loop? My biggest concern is future leaking from degrading o-rings from neglecting to check them every so often to make sure they are functioning properly.. I can already see some cracking with the radiator ones but I can't actually see the o-rings on the waterblock for the CPU and GPU so it would take a bit of work to take it all apart.
Do you recommend anything besides o-rings, like teflon tape? What about lubricating the o-rings with a silcone based lubricant? TIA.
Most people do a tear down and rebuild on their loop every 6 months. Usually with new tubing and coolant, and if o-rings are cracked replace them! If they look like they might leak, then they will.
I typically don't do any yearly or semi-yearly maintenance. Why bother? If it ain't leaking and you got no algae what's the point? Coolant will leak out through the tubing walls so that may what you are smelling. My suggestion is to quit putting toxic chemicals in your loop and then you don't have to worry about this shit. :)
Yeah, DEATH-cool is bad!;)
I strip down my loop once a month or so, depending on how I feel (or if new products are released). I always replace all the tubing to keep a fresh look.
I think thats way too extensive maintenance. There is no wat that 1 month watercooling will need maintenance if built correctly. Though, who am i to tell anyone where to put their money on.
I have been running my loop for 8 months, I had to take it apart to change my video card....
If it weren't for that, I would not have even touched it...The fluid is nice and clean, and I'm leak free..I don't see any reason to try and fuck that up..:)
