spacing guild
- Dec 9, 2010
Whatever. You just go down your one track mind with your imaginary needs. 6gb is completely unnecessary for anything other than heavy transcoding work that requires lots of RAM. Gaming often requires no more than 3gb RAM. Yes, it is possible to squeeze a few hundred, increasing by 5mhz with a 33 multiplier does give you 165 mhz overclock.
Right now...with no games running and Aero turned-off, I am at 1.99 GB. With SupCom running 8 players @ 750 units each, I will run well over 2GB...something like 2.3 GB probably. I need the extra two GBs as a good buffer.
I don't want to spend good money after bad. If what i'll need to overclock the Phenom still doesn't cut it...I'll have to RMA and it will be hassle plus restocking fees.
Its your money. I hope for my sake that you are wrong and in 6 months your talking about how SB is disapointing and that you should have waited for SB. Its nothing personal but I am an AMD fan and I am hoping for the best. But I am building a new PC this year and the better CPU for me gets the purchase. If its SB then so be it. I just think don't think your way of going about it is smart.
I'm right there with you bro. I graduated from a 1 Ghz P3 to Athlon XP 1500+, to Barton 2400+ to Athlon 64 4000+ and a few AMD cpus in between. Then I read about hyperthreading with P4s so I got decent P4 system...totally disgusted with it. I installed it and boxed it up for return the same night.
The truth is with Core Duo and Core 2, Intel took over and they are quite far ahead. AMD's track record of late is price-performance and efficiency. I think Bulldozer will be a good platform...I just don't see the raw power that I want coming from BD.
If I am wrong in six months...I'll be back.
