Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ok so i got the mag and i dunno how to make the imput and output on them to a 3/8" ID, like anyone have that setup and can tell me what to do abotu then ends?
Your 3/8'' ID hose will fit over 1/2'' barbs. You will probably have to heat the tube ends in boiling water to soften them up first, but they will fit.
