TeeJayHoward
Limpness Supreme
- Feb 8, 2005
So in MacOS, you can block-select text by holding down option (alt) and selecting the lines you want. Cool. Works well. But I'm a little spoiled by Notepad++ which allows you to replace the text you just selected just by typing. Is there a way to enter the same text on multiple lines in MacOS?
