I built my E6600 machine, and then finally decided to check the temperatures. My motherboard temperature is high, not sure what to do.
I have this Lian-Li
http://www.newegg.com/Product/Product.asp?Item=N82E16811112102
Any reccomendations on a fan to cool it down? I was thinking about this Zalman
http://www.newegg.com/Product/Product.asp?Item=N82E16835118003.
Will that help my motherboard Temperature, or just the CPU. The CPU is running at a cool 38 degrees celsius, while my motherboard is in the 50s.
Thanks!
~J
I have this Lian-Li
Thanks!
~J
