Machine Exception at bootup
Icheb
Hi,
whenever I start my PC and Windows gets past the loading screen I first get a black screen which turns into a Machine Check Exception BSOD after a few seconds. I can't post the specific error codes since the PC reboots after what feels like a few milliseconds.
System Specifications:
Windows XP Pro SP2
AMD Athlon 3500+
GeForce 6800
Asus A8N-E
I have never OCd my PC and the CPU's and graphics card's fan are working properly. I reapplied the thermal grease for both the CPU and the graphics card which didn't help.
It always happens RIGHT after Windows XP's loading screen and I can't seem to be able to figure out what's wrong. Does anyone have an idea of what is broken?
can you boot into safe mode? if so, turn off auto restart. To boot into safe mode, hold down F8 shortly after turning the computer on, after it POSTS, but BEFORE the windows loading screen.
right click on my computer, properties >> advanaced >> startup and recovery settings >> system failure >> uncheck the auto restart checkbox
then post your error code. or just go to http://www.aumha.org/a/stop.htm and lookup your error code.
How long have you had the problem?
Did anything happen before the problem started, such as install new hardware or software, hard crash or reboot, anything that might have affected the system files?
Next step would probably be to boot off the windows CD and attempt to repair the existing installation from there. At least use it to run check disk and verify the file system integrity.
I started experiencing occasional system freezes for a while before this happened. Maybe one every few days, nothing really annoying. Right before this happened it froze again and after that this problem started.
I actually also tried reinstalling XP, twice even. During each installation it froze once but eventually it worked. Then the installer wants to reboot and after the reboot it BSODs as usual.
sounds like faulty hardware. did you run any hardware tests? get memtest to test the ram. run memtest overnight. go to your hdd manufacturer's website to get their hdd fitness test.
