mach2 cooled GT
plur
I have a Mach2 ST sitting about... is there anyone selling some kind of kit so I can cool my 6800GT with it?
Or could I somehow make it fit!?!!
I can imagine how nice 500MHz+ core would perform :D
You might want to do some research on how to make your own evap head for it. Since Nventiv went out of buisness I doubt a commercial solution will be released. If the Evap head is small enough to fit inside the mounting holes maybe you can fab up some sort of custom hold down.
If that doesn't work you could always try some thermal paste.
I
I
I
I
I
I
I
lol j/k :)
Edit: I also don't know if the thermal throttling issue has been solved yet, if not it would be a pain in the a** to get it to work properly. Better off to buy a x800xt.
