centvalny said:I need some info about using mach1 to cool a gpu. Mounting issue and temp. etc. Also, stock or mod. Thanks and merry xmas.....![]()
James Earl Ray said:Man, things are getting crazy around here now!![]()
centvalny said:That's my thread
Edit: With APC 1500VA now I don't have to worry with voltage fluctuations.
I'm not worry with saving files etc. The only think is at high oc acpower fluctuation can kills, especially winter when my local utility co. can't be trust...Protoform-X said:My 1500VA APC can keep my 19" LCD, Vapochill LS, and FX-53 machine running for 12 minutes when the power goes out. That's pretty good, me thinks.
centvalny said:I'm not worry with saving files etc. The only think is at high oc acpower fluctuation can kills, especially winter when my local utility co. can't be trust...![]()
Overload with Belkin 1200VAcornelious0_0 said:Really? Guess I didn't notice......cool stuff, what'd it set you back?![]()
centvalny said:Back to post......anyone with phase on gpu?
James Earl Ray said:By June I should be running dual Vapo's. And maybe a dual core FX-? But I want to see how ATI counters SLI first.![]()
centvalny said:you guys wanna know something about vapo?![]()
cornelious0_0 said:Seconded.![]()
Set it up.....you can change rad later...James Earl Ray said:Ill have first hand info, If Fedex ever shows up with my rad!!! I am tempted to set it up now with my DTek.![]()
James Earl Ray said:I have no place to put the 120mm rad in the case without cutting. Thats why I want to try the BIM rad first.
Thanks for the info. Preppin the vc is not gonna be a problem...we all aware that condensation is enemy #1VO_Nuclear said:All that you need to do is send the unit to Chilly1, PC_ICE, Baker, or Bowman and have them put a mount kit on it. They all have similiar mounting systems, and all will work very well. Prices vary, so I can't quote them.
If you are getting a MachI, I would suggest having them re-gas the unit with r404a or r507, and put a different block on it. It will function much better, and recover alot faster.
Overall its easy to setup a MachI for GPU cooling. Insulating a gpu card is a bit trickier than a CPU, as you'll need your own way of stopping condensation. Anyone who has dealt with a Vapo or any other PS system before will do fine.
That is a smart way to savecornelious0_0 said:What I want to find out here is how much it might cost to GET a MachI regassed with r404 or 507....because the MachI ST for example runs r134 but is almost $500 cheaper then the Vapo LS for me to buy new.....and I'd rather save some cash if I can.
VO_Nuclear said:To have a MachI re-gassed and re-tuned is around or slightly above $200 from someone like Bowman or Baker. I'm not sure about the other guys, but I would bet it's close in price. The mounting system and config would add to the price, but I'm not sure how much.
In the end, the price ends up being about the same. You buy a MachI for $500, pay shipping and all to you. Then you pay at least $200 to have it re-gassed and then shipping to and from again. All of the shipping, boxing, actual cost, etc.. easily add up to a LS or GT.
The canadian guys may want to find a refigeration shop around that can re-gas the unit. It may be cheaper, and you won't have to pay shipping. You'll have to create your own mounting system though.
centvalny said:What I need actually a mach1 and modified the mounting to fit...got that. Can it sustains minimum raise on evaporator temp if mounted on xtpe with heavy oc?? Without regassed
ie: Vapo ls evap. temp upped to -42/39C from -53C under load from fx55 at 3.35Ghz/1.75V, more than that it will reboot.....
Thanks. How you can set or find out the gpu voltage? is it through agpV in bios?cornelious0_0 said:I would think it would be alright, I realise that the LS is running r507 and the Mach I is (I think) using r134.....but you should be fine. I look at my setup for example.....under load, my XT-PE @ 1.85v and my 3.4E at 1.53v both get up to about the same load temp.....about 42C.....and while this isn't AS contrete information/evidence as you'd like.....its something.![]()
centvalny said:Thanks. How you can set or find out the gpu voltage? is it through agpV in bios?
James Earl Ray said:1.85 is fine for water. Come on and do it already!!![]()
