HardOCP News
[H] News
- Dec 31, 1969
If youve never seen a MacBook that has been run over by a truck, this is your lucky day. Surprisingly enough, the MacBook still works
.heh
kidding, its hosed. Thanks to Jase for the pics.
At least the guy now has a really interesting conversation piece.
It's still just as useful as it was before it was run over.
Apple engineers are mulling how to build a curved LCD now so they can sell this as the "thrift shop look" Mac.
Back when I worked in a computer repair shop someone brought in a laptop that had been run over. It was a Compaq and although the damage was heavy, it did still work. The LCD and the floppy drive were toast. Other than that it worked.
Don't know why I kept saying Air...must because now it's as flat as one.![]()
That will teach you for going Mac lol![]()
really now...pc's never get run over? The Macbook pro aluminum unibody is probobly alot stronger than most...
To clarify, that Macbook is in worse shape after being run over than almost any laptop I've ever seen that suffered the same fate. Plastic is going to be more flexible. Aluminum, when bent sufficiently (and it doesn't take much) will retain the bent shape. Plastic when made correctly will be stronger and more resilient than many metals will.
Not to mention, if you run over and bend aluminum, you take everything inside it with it. If you run over plastic, it's likely to shatter around all the hardware while the hardware remain intact.
Heh, a ThinkPad would have survived that.
Remember Panasonic has a nice laptop line
Hmm Perhaps if I start to get issues with the ram slots in my IBM ThinkPad T30, I could always make a truck block out of it![]()
Hi I'm Mac, and I'm a Mac Truck!
Surprisingly enough, the MacBook still works.
How about we finish it off using the .50 cal rifle with an API round.
