I have a Macbook pro mid 2011. I have thunderbolt on it. I am thinking about doing a dual monitor display using either two 23" or two 21".
I was looking at a Matrox Dual Head to power the two displays.
Here is the product on Amazon, and Newegg:
http://www.amazon.com/dp/B000OV818I/?tag=googhydr-20&hvadid=6063461727&ref=pd_sl_4ey5qa5g53_b
http://www.newegg.com/Product/Product.aspx?Item=N82E16815106015
Has anyone used this model, and how well does it work to have two separate displays? I have read that the menu bar spreads across both, is this true?
Thanks.
Thanks.
