Macbook Pro LCD backlight :((
Nakamori
Hey guys,
I have an old 2.33 C2D Penryn MBP that i just finished chanigng the thermal paste on. the problem is that now the backlight doesn't work. I have it running on an external monitor right now, but i just wanted to ask before I go ahead and order another LCD + inverter if there was anything on the motherboard itself that i could have messed up to have the backlight go out.
after all, i wasn't touching the lcd at all while working on it... any thoughts?
I'm pretty sure the Penryn based MBP has an LED backlight. Do the LED based LCDs use an inverter?
If it worked before you messed with it, could just be that you knocked a connector, just open it up and take a look around, try ifixit.com for a guide for replacing an lcd on your model of machine, that way it'll show you all the connectors that the lcd is connected with.
