macbook pro fan noise question
beemil
I have had my macbook pro for about 3-4 months now and today I started hearing this weird noise out of my right side fan. It isn't loud or anything, but still fairly annoying. It sounds like a very soft (really soft) clicking noise, although the fan is still working and going at the default rpm speed. I am wondering if this is something that I should just take my keyboard off and investigate myself or if I should just send it in to applecare. I don't really have the time right now to go a week w/o my laptop, however. It seems pretty simple to just remove the keyboard and look inside. Anyone else had/have this issue?
you have to remove the whole top case. if i recall correctly, it's 18 screws. the fan probably needs to be replaced under warranty.
