MacBook Pro battery cycle rate
Colonel_Panic
My mid-2009 13" MacBook Pro has been in heavy daily use since the end of 2009 and the AppleCare is done at the end of 2012. Checking iStatNano, I see charge cycles of 188 and a health of 88% new.
Anyone know what rate might allow a battery replacement through AppleCare?
Those with similarly aged machines, what are your cycles and health?
AppleCare still only replaces batteries in the first year, like the original warranty, if I recall correctly.
At least that was the case with my 2008 MacBook pro.
It would have to be an abnormal amount of battery loss denoting a defective battery.
I had a battery replaced in my (almost) third year of Apple care because I had a battery that cycled 40 times and was at like 70%.
Applecare doesn't cover "normal wear and tear."
Colonel Panic,
88% sounds about right given the age/cycle count. Are you noticing some large amount of lost battery life or something? Or you just see 88% and think that needs replacement? I'm not really seeing a problem here. This is normal wear and tear.
I know your question was specifically about what Applecare covers in this department - wouldn't it be simple enough to just.. check with them? I don't mean to sound like an ass, but they can give you a quick answer. Probably much faster than these apple forums, given their low activity for the most part.
It's "supposed" to be 80% after 1000 charge cycles; it's presumed that this is what the battery health percentage means.
To be honest though, I'd ignore it. Concentrate on battery life instead; after all, isn't that what the battery is for? :)
Colonel Panic,
Thanks for the thoughts. 88% is in the "butter zone", so to speak, so I'm more interested in seeing at point I should consider an AppleCare replacement before the warranty runs dry.
It would have to be so bad that they determine it's defective. If it couldn't hold a charge for an hour with normal internet use, then maybe you'd get somewhere, but it would probably have to be like <30-45 minutes.
