winston856 said:I'm really considering buying a macbook just so I can get the best of both worlds. I'm not ready to buy a laptop yet but when I do I think it'll be a macbook. As long as it can play counterstrike I'm good![]()
winston856 said:I just figured that the hl1 engine is pretty old, but I guess the graphics solution is pretty crappy in a macbook...
winston856 said:Is there a bigger battery I can buy that would give me longer life?
winston856 said:Thanks.
I've been customizing macbooks on apple's website and it's become apparent to me that they like to try and rape you on the HDD pricing...
Fryguy8 said:Why can't they just make a 15" macbook instead of pro.
SteveW928 said:Well, it isn't so much a matter of being crappy... just more like what it is... an integrated GPU that isn't built for advanced 3D. I actually does really well for other stuff, and even will play HD video, etc.
Here is a cool site with lots of performance comparisons on Mac hardware:
I'm linking to a page that compares Core Duo to Core 2 Duo MacBooks... but you can see what happens when they get into the 3D gaming.
http://www.barefeats.com/mbcd8.html
As you can see... not a whole lot of difference between CD and C2D processors. But, the MB falls way behind the MBP, or even the older PowerBooks when the 3D games come up. But, this is because the other models have specialized GPUs for that.
If you don't need that though.. the MB is one wicked fast laptop for its price.
-Steve
SteveW928 said:Hehe... I suppose... and there are also people complaining that they don't make a 12" Pro.![]()
However, the MB really isn't all that much smaller than the 15" MBP. Its less than an inch depth, and only about an inch width... and they are about the same thickness.
-Steve
MrGuvernment said:You could, but some people dont want the extra weight and size and lower battery life.
Shivetya said:the weight isn't different enough to be noticable....
I dont' need graphics, I just want a bigger screen for productivity.
CEpeep said:SteveW928, why in God's name did you just post 5 times in a row? Use the edit function if you want to add more quote replies, not a new post.
BrokenBoySoldier said:Does the black macbook come with the isight camera?
winston856 said:One of the last things I'm looking at regarding the macbook is the choice of processor speeds.
I can get a 1.83GHz model with a 120GBHDD 2GB's RAM $1550 on apple's site. The next model is the 2.0GHz chip with the same 120GB HDD, 2GB's RAM and it's $1627. So you figure $77 dollars for 200MHz but what is that going to cost me in battery life?
Should I go for 200 more Mhz? What would that cost me in battery life? 10-20mins+?
winston856 said:Could somebody provide some insight on this ?
Optional87 said:![]()
It definitely does
In fact all the Mac notebooks have them.
BrokenBoySoldier said:that's creepin' me out![]()
BrokenBoySoldier said:i got one more question about the macbook...i've decide to get the black macbook with 1Gb Ram and 180Gb HDD, i read somewhere that office for mac runs slow with 1Gb of Ram...can anyone confirm/deny this...cheers
also that picture ain't that bad...![]()
Shivetya said:The same reason they don't offer graphics in a regular Macbook.
Money, they can make tons of it as most Mac fans will put up with lack of customability. You can do these things when you have a monopoly on a product
winston856 said:Cause he's a n00bie trying to get some postcount his posts are pretty quality so it doesn't bother me
winston856 said:Thanks again.
I have a couple more little questions.
1. If I bought a macbook off of apple's store, does it come with the operating system disc? Or does the OS just come pre-installed and I have to buy my own disc.
2. Can I plug in my logitech G5 mouse or any regular 2 button mouse and use it in OSX ? Or do I have to buy a special apple mouse?
SteveW928 said:1) Yes, it comes with a DVD that has OS installer, as well as installer for bundled apps. It isn't exactly the same as buying a copy of OSX off the shelf, in that it only works on the MB.... but its fine for what you want it for. (also, the MB is pre-installed with everything too... but I sometimes just re-install myself anyway. Still, the imaged systems out of the box have been quite good.)
2) I'm not sure about the exact model of Logitech mouse... but I'd say generally yes. Every USB mouse type device I've ever used works fine. The only 'gotcha' here is that if the device has a bunch of special functionality, you might not be able to use it if they have not written and OSX driver.
OSX supports, from what I know, left/right buttons, scroll wheel, and I think scroll wheel click, with no drivers. The rest of special feature, you need to check with the maker for OSX drivers.
-Steve
synergyo1 said:I apologize if you noted this already but...
The 1.83ghz only comes with a Combo drive, whereas the 2.0ghz comes with a Superdrive.
TheLordsServant said:I have never had a problem, I have a 13 dollar logitech mouse I bought from CompUSA and it works just fine, so I would definitely say that your G5 ought to work just fine
Optional87 said:I mean with the extra buttons there are problems sometimes. Logitechs MX518 I know doesn't work 100% with OS X, but it does gives the same basic right-click/left-click/scroll wheel functionality
winston856 said:Thanks, that's all I needed to know on that front.
Also, yes I've noted the differences between the combo drive vs. the super drive. I was actually going to post and ask about that but the answer was right there on apples site and was kind of a no brainer to figure out![]()
I was all set on getting the Macbook 1.83GHz model until I saw that it didn't come with the super drive![]()
So now that I know if I got that version I wouldn't be able to burn DVD's which I need to be able to do. So I have to buy the 2.0GHz model with the super drive. Which honestly isn't all that more expensive.
Now actually I've just seen the apple warranty costs $350 bucks to extend beyond the basic 90 day warranty. That's quite a difference but I guess if I am expecting to have the laptop for a couple years that I should probably buy it even though it's pretty expensive. It turned my $1600 MB into a $1950 MB. I'm just going to squeak in under the $2000 mark for one of these things and I don't even get a dedicated graphics solution! LoL
I just love the look of them though and I already have a gaming computer (the box in my sig) so I'm not to disheartened about that.
Would you all recommend the apple extended warranty for $350?
synergyo1 said:It is 90 day complimentary support, but it comes with 1 year hardware warranty. You can hold off puchasing the Apple care until right before the 1 year warranty runs out. On eBay you'll be able to find Applecare kits at a lower price. If you do end up holding off of the Applecare make sure you apply it before the 1 year runs out.
BrokenBoySoldier said:is iWork or office 2004 better?
SteveW928 said:A couple notes on HDDs....
1) I think it is pretty easy to swap out hard drives on the MacBook... so you could probably upgrade the drive in the future without too much trouble (ie: you don't have to disassemble half the machine like in the past...)
http://www.appleinsider.com/article.php?id=1750
2) also just an FYI that larger sizes give you more disk speed... maybe even more than the 7200 RPM drive... which I don't like because they are noisy and suck more batteries.
http://www.barefeats.com/mbcd7.html
-Steve
MrGuvernment said:my 7200 60g is as loud as my 60g 5400rpm was, they arent much louder, also they dont suck out that much more battery life either.
and unless your drive is %80 full, the 7200 are faster in every other aspect.
