MacBook CPU Swap?
dhongyt
I bought a MacBook about 2 months ago and I was wondering if it uses the same Core 2 Duo chip as a desktop? If so, can we swap them around and how?
I'm planning to swap my E6600 with the MacBook's E4500 (I'm guessing its a E4500 because its a 2.2GHz laptop).
No, it uses Merom, the mobile version of the C2D and it's soldered onto the motherboard.
It's a T7500, not a E4500. And like the previous poster said, you can't swap it out.
i loved everything about my mbp until I read this thread, thanks guys lol.
fucking apple...
...you really expect a 1" thick portable to have a socketed processor? seriously?
fucking apple...
Well, the PCB + the Socket would be about 11mm thick... Add in the 10mm heatpipe assembly, 2-3mm for the case and 6mm for the screen, and you have about -5mm for a CPU... That's assuming the board is backed right up against the case, which would be impossible.
Even if he could unsolder it, it uses a different amount of pins. 478 or 479, can't remember.
The mini's are socketed core duos and core 2 duos, socket M. I didn't realize the MBs used a BGA package. Most of the Napa (socket M) and Santa Rosa (socket P) laptops use a socket.
lol, sorry, what I meant was...
Are you serious? If you've been measuring your laptop, I think it's time to get out and find a girlfriend or something.
Part of the reason apple solders the CPUs to the motherboards in all their laptops because they aren't keen on user upgrades. They are after all in the business of selling computers and software rather than upgrades... They'd rather you buy a new macbook than upgrade your old one.
This also gives them more control over what type of machines run OS X so software development can be more streamlined.
Hehe. They were all estimates... When you're as knowledgeable about computers as I am, you can throw around some semi-accurate numbers without too much difficulty.
And I've got a girlfriend thank you very much :p I haven't been single for longer than 22 hrs, since I was 14.
/cynicism
exactly.
i beleive the solder it in on the Imac as well, and they could fit a CPU sockt in there easy (they can fit a standard 3.5 HD)
exactly.
I'm pretty sure all the Intel based desktop Macs have had socketed processors. All of the intel based portables are using soldered chips.
