Macbook and Xbox 360?
KaosDG said:
Applications -> Utilities -> terminal
at the command line, type "ping 192.168.2.2" (without the quotes) and press enter.
(press ctrl+c to stop)
you should see output like this:
Code:
mkennedy-laptop:~ karl$ ping 172.20.14.1
PING 172.20.14.1 (172.20.14.1): 56 data bytes
64 bytes from 172.20.14.1: icmp_seq=0 ttl=64 time=0.277 ms
64 bytes from 172.20.14.1: icmp_seq=1 ttl=64 time=0.283 ms
64 bytes from 172.20.14.1: icmp_seq=2 ttl=64 time=0.266 ms
64 bytes from 172.20.14.1: icmp_seq=3 ttl=64 time=0.271 ms
64 bytes from 172.20.14.1: icmp_seq=4 ttl=64 time=1.034 ms
64 bytes from 172.20.14.1: icmp_seq=5 ttl=64 time=0.295 ms
64 bytes from 172.20.14.1: icmp_seq=6 ttl=64 time=0.287 ms
^C
--- 172.20.14.1 ping statistics ---
7 packets transmitted, 7 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.266/0.388/1.034/0.264 ms
i tried it again and got this:-
Last login: Fri Dec 22 21:22:41 on console
Welcome to Darwin!
joseph-roberts-computer:~ josephroberts$ ping 192.168.2.2
PING 192.168.2.2 (192.168.2.2): 56 data bytes
64 bytes from 192.168.2.2: icmp_seq=0 ttl=64 time=0.059 ms
64 bytes from 192.168.2.2: icmp_seq=1 ttl=64 time=0.087 ms
64 bytes from 192.168.2.2: icmp_seq=2 ttl=64 time=0.104 ms
64 bytes from 192.168.2.2: icmp_seq=3 ttl=64 time=0.082 ms
64 bytes from 192.168.2.2: icmp_seq=4 ttl=64 time=0.064 ms
64 bytes from 192.168.2.2: icmp_seq=5 ttl=64 time=0.097 ms
64 bytes from 192.168.2.2: icmp_seq=6 ttl=64 time=0.092 ms
64 bytes from 192.168.2.2: icmp_seq=7 ttl=64 time=0.086 ms
64 bytes from 192.168.2.2: icmp_seq=8 ttl=64 time=0.087 ms
64 bytes from 192.168.2.2: icmp_seq=9 ttl=64 time=0.086 ms
64 bytes from 192.168.2.2: icmp_seq=10 ttl=64 time=0.083 ms
64 bytes from 192.168.2.2: icmp_seq=11 ttl=64 time=0.085 ms
64 bytes from 192.168.2.2: icmp_seq=12 ttl=64 time=0.086 ms
64 bytes from 192.168.2.2: icmp_seq=13 ttl=64 time=0.087 ms
64 bytes from 192.168.2.2: icmp_seq=14 ttl=64 time=0.090 ms
^C
--- 192.168.2.2 ping statistics ---
15 packets transmitted, 15 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.059/0.085/0.104/0.011 ms
Yes the default gateway is the router network ID(ip adress).
I wish i can help you, but i recommend getting a long ass ethernet cord and run it from your airport. Then problem solved.
I haven't read through the entire thread, but it sounds like you still haven't gotten it to work properly. There should be a way to do it, because I remember I used to do the same thing with my laptop and Xbox. Worse comes to worse, you could install bootcamp and do it through windows, cause I know for sure it can be done in windows.
Let me just warn you though, you're going to get terrible ping times. My setup didn't work well at all for playing on Xbox Live. If you're close to your router, you might have better luck. I was fairly far away (like 3 out of 5 bars on my laptop).
