Most touch pads support scrolling. Alps is one of the more common touch pad vendors. You have to have the Alps drivers installed. You can configure one of the sides as scroll areas. If you make a scroll gesture (such as dragging from top to bottom on the right edge), it was scroll. You can do vertical and horizontal scrolling. You can also configure tap gestures such as forward and back.
