Mac Pro-style fixed SATA connector/power mounts?
rush24t3
Subject's a little oddly worded, but I'm trying to get my cables as clean as possible in my Cooler Master 690 case and figured maybe there existed fixed drive connectors like found in a Mac Pro.
Basically, I'm searching for a bracket or combo interconnect that combines both SATA data and power, and then you can connect it to extension cables that are out of the way. I've been looking around but haven't yet found such a beast.
Other than the A71, which had the hot-swap boards with SATA power/data connectors on-board...not sure what other alternatives are out there. Otherwise you could always use combo connectors (and make the connection at the bottom/behind the mobo).
no real input other than it sounds like a great idea to keep things clean. Let us know if you happen to find anything
Silverstone has hot-swap adapters (CP-05 is the model number) but I am not sure if they fit in non-Silverstone cases.
