Mac Pro hardrive question
Hi I'm going to configure a new Mac Pro. I will be installing Windows Vista Ultimate 64 bit on it as well. Could I configure the Mac Pro with two internal 1 TB hardrives and use one for Windows Vista and the other for Leopard? Or would it be best to buy one 1 TB hardive and split it for each OS?
If you are going to be using the each OS's frequently then do each HDD separately, but If you will be using one more than another, do the split route. I guess it's all personal preference.
Also think if one of them dies and your HDD is split in two, then both OS's will go down....
Personally I'd do 2 separate ones, but that's just me.
