poirier.simon
- May 5, 2008
That my first mod ever. I wanna put a ibook G4 in a case of none working Nes (yes, that can exist). But i don't want to do any new hole in the Nes Casing.
I got all the part from my old Apple Tech job. (spare part left by costumer)
I buy sleeving and shrink tube to make clean wire job inside ( you will never see a Nes that clean)
I got a dremel and some stuff to cut metal, but i choose to take a side panel of a P1 server ... that is so thick, but that the cheap metal i got. I already cut 2 metal piece, 1 for the logicboard and one for the video connector. (pic will come later). I cut them square to begin, the I will do the finishing job to give them there final form. (hole for screw and wire)
Since i got to to fun with my dremel and change idea, i already cut all the plastic spacer inside the casing at the same level than the riser for expension. So now I will have to do some metal spacer.
I will also include a IR receiver for my Macally keyboard mouse combo, and reroute the Power LED to the Nes Power Led. I will also reroute the IR receiver to a New position, since I'm not sure if it will all enter in the nes cartridge.
I will use the power switch of the nes and circuit, but I change the white led for the Red led (not in pic) I use the circuit board for the switch and the led. I just remove the blocker for the power since i need a non statinnary power switch.
For the sound i will use the iDog wiring, it will be shorter and sleeved
For the logicboard, i already cut some of the brace, but need to continu that soon.
I twist the heatsink to gain some space.
I remove the white cover of my mini-vga to video (still use RCA and S-video since my Tv isn't a HDTV)
The DC adapter that i will sleeve and find a way to screw it to the mother board trail or it how (not sur for now.
The stock fan, maybe i will replace it, not sur for now, but i make the whole thing run for 48h in the casing (w/o anyholder) w/o fan and I didn't get any problem. I got a on/off switch that i will use if i but it in.
The top part of the case will contain antenna and internal speaker.
I'm not sure if it's good to sleeve antenna ( anyone know ??) but i think the antenna part is just the metal end.
here a plan of how i see the stuff inside
Red = IR (if it inside of the Mario Bros/Duck hunt cartridge)
Green = Logicboard
Blue = Power button
Yellow = DC board
light blue = Video connection
Coming soon (since no photo but already done) LED changed on power button board, first cable sleeving and 2 metal plate for the logic and video.
I got the 14" LCD that come with the ibook, but i don't find anyway to but it in, too big to enter (i was thinking of a nes laptop)
Hope you will enjoy the project.
Green = Logicboard
Blue = Power button
Yellow = DC board
