zwbuntster
- Jun 26, 2005
Looking for some ideas for the best possible setup for the following:
27" iMac in one room (housing any sort of movie/tv files, automatic torrents for shows, etc)
Home Theatre in living room with DVD/BluRay
Basically, I previously had the two connected directly with HDMI and could send HD/5.1 right from the computer. Now that I have moved, they are no longer next to each other, so basically trying to figure out the most elegant and simple way to be able to stream or access any sort of file from the computer onto the home theatre. Ideally this would include 5.1 support and 1080P. Netflix, etc access would also be nice somehow integrated. Worst case is through an xbox separately but would like to avoid if possible.
Everything will be connected to the same network if that helps. Thanks
