M7NCD and PC3200 error
RG_Havok
:confused:
I get a beep code when i boot up ..no display, just a beep.
specs: Biostar M7NCD board
Athlon Xp 2000+
512 Rosewill PC3200
Geforce FX5200 128mb
WD 80gb Drive
LG cdrw 52x32x52
I'm building this system for a friend, I've tested all these parts on my asus rig and everything runs fine, even the memory. I've looked all over the manual and the biostar webpage, with no luck, Am i missing a jumper? or is there something that needs disabled?
Oh 1 more thing...the system runs perfect with a stick of PC2100 in it.
Any help fellas would be awesome! TY in advance.
the reason it runs perfectly with the pc2100 in it is because when you boot up initially the bios will run whatever ram you have at "SPD". and pc2100 runs at 133 just like your processor does. but_ "SPD" for pc3200 wil run at 200 instead of the 133 that pc2100 will run at. the thing to do would be to get to the bios before you even get into windows and manually set the bios to "expert", and your dram section to "manual" or "expert", then downclok the pc3200 by setting it for 133. you do this by setting the ram to run at 100% of your fsb speed - eg: fsb=133/dram133. so the resulting frequency for your dram speed running at 100% will be 133. that's called syncing your fsb and dram. you were "async' whith pc3200 and your 266 fsb (133x2) cpu before more than likely.
