- Aug 24, 2004
What up [H] readers,
I have an eMachines m6811, and am curious about upgrades. Here's the deal:
I know the hard drive is slow. If I upgrade to a 7200 / 8 / 80gig, how will battery life be affected?
If I choose to upgrade RAM to 1.2 Gig (1G + 256) up from 512 Meg (2x256), what performance difference will i see? Also, if I use a single 1 Gig stick of DDR400 (as i have read using 2 sticks of DDR400 won't work) will i see more of a performance gain over the existing DDR333 even at 1.2 gig of DDR333. Thirdly, will more RAM reduce the use of pagefile and reduce waiting for the slower hard drive which seems to bog the laptop down?
What is a good brand to go with for RAM if i buy a Gig stick, while still being reasonably priced?
I know this last one is really adventurous / foolish, but here goes. The existing video chip, ATI Radeon 9600 with 64 meg of dedicated ram; the chip is completely self-containing, having ram and gpu and all on a chip that is pin-compatible with any other FLEXFIT ati chips (i.e. mobility Radeon 9700 etc.). This chip is soldered on to the motherboard right? Does anybody have actual pictures of the chip itself, on the mobo? My mad-scientist line of thought is that if i were to obtain an M11 (9700) chip, would it be possible to solder the new one into the motherboard? I am curious to see what it looks like from top, and on bottom where i assume the solder points would be.
Any other upgrades I have missed?
btw specs on m6811 are:
AMD Athlon64 3400+
512 meg of DDR333 PC2700
ATI Radeon 9600 w/ 64 meg
80 gig 4200 rpm 8meg cache
AMD Athlon64 3400+
